Is there a limit to the data size of a USB stick used on a DST?
I have a 2 GB USB stick I use on my DST for demos without problems. I have tried other higher size data sticks and the drive does not recognize them. Is there a known limit to the size of the sticks that can be used? Also, is there any know problem with the DST recognizing USB 3 sticks? Thanks in advance for any help!
oops
Do you mean the PST? Or did I miss the release of a new product?
Yes, I do mean the PST, sorry…
I do not have a PST but suspect it expects USB drives formatted FAT32. Do not use exFAT.
I suggest reformatting the drive.
