My new DirectStream Junior is now settled in and sounding great. It came with Yale and now I’m ready to try Torreys. I note that PS’ advice is to use a 2GB USB memory stick but the download, even when unzipped is less than an order of magnitude smaller than 2GB. I’ve a 1GB stick but I’m wary of using it just in case the DS Jnr uses the remainder of the stick’s capacity as working memory (though I’d expect a multi-£k product to have enough internally). I don’t want the upgrade to fail and leave my DS Jnr bricked until I get a fix from PS. (I’ll even be running the DS Jnr temporarily from a computer uninterruptible power supply just in case of a mains failure [uncommon but why take the risk?]).
So…
• Is 2GB essential?
• Is more okay? (The advice doesn’t say ‘at least 2GB’
• Why 2GB for downloads under a tenth of that?
I’ll be grateful for any technical information or practical advice based upon experience.
Peter
THANKS
