Does anyone of you can give me some comment about the power supply on LANRover. I am going to get a LANRover and wondering, should I connect the LANRover to PowerPlant P10 directly or better to get a individual LPS instead of the stock power supply unit attached.
I think an upgraded power supply should help, but even then you would want to connect it your P10 anyway right? If you’ve got a P10 you might as well use it.
For me I’m going the Uptone LPS-1 power supply. That seems to be the only one where the feeding power doesn’t matter because the final output comes from a switching ultracapacitor bank so the AC power is never in actual direct connection to the DC output in any way.
