LPS Power Supply Recommendations
So, late to the party I know, but I just received a Matrix and am looking now for an LPS power supply.
I see old postings of uptone used for $200. I see on ebay there are chinese ones listed at $100, but after shipping it’s $160 or so. Can anyone recommend one new for about $100 that they have used and works well or does anyone know of someone with an older model interested for around $200 ?
Thanks
TD
Don’t know what voltage you need, but have you looked at Small Green Computer?
Good Luck!
Thank you @softlight64
I made an offer on an uptone LPS today. If it falls through I will check out green comp. So youve used it and had success? Anything you could share on it?
https://forum.psaudio.com/t/price-drop-sonore-sig-rendu-se-optical-uptone-lps-multiple-etherregen-wireworld-hdmi-starlight-7-matrix-spdif/38077
thanks!
Tony
I’ve got two of these. One has been in service since 2016 and the other one over two years. Less than $100 with shipping.
https://www.aliexpress.us/item/3256803509834959.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.5.57ccTDCkTDCkDb&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.354490.0&scm_id=1007.40050.354490.0&scm-url=1007.40050.354490.0&pvid=75f43a11-dc43-4f57-8880-948eebdcbe96&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:75f43a11-dc43-4f57-8880-948eebdcbe96,tpp_buckets:668%232846%238109%231935&isseo=y&pdp_npi=4%40dis!USD!58.00!51.62!!!58.00!51.62!%402101fb1017214892951017924ed8cc!12000026851211165!rec!US!!AB&utparam-url=scene%3ApcDetailTopMoreOtherSeller|query_from%3A
Thanks @dawkinsj I think Im going to move forward on an Uptone that came up for sale, but thank you for the rec.
Linear Tube Audio makes a great LPS…
Are you selling?
Would one of these happen to be the correct voltage for an EtherRegen?
EtherRegen will work with 7-12V.
RSVP.
Ive made contact concerning the Uptone LPS. thanks @jazzophile
I always keep a side-eye on the Marketplace thread :grinning:
I just read several posts that the uptone LPS fails with the “Orange” light of death… :frowning: maybe this is not something Im looking for especially used. Thoughts anyone? Maybe go with something like @dawkins uses???
@ [dawkinsj]
Do you have any thoughts on these LPS’s you’re using? Have you compared them to others? Do they come with DC Output cables do you remember?
Thanks
Scott
No not selling but yes they sell them in multiple voltages that should cover the range provided for the EtherRegen. The next step up the line would be the LHY PS that you can buy from Todd at TEK Services in Texas. He sells and services everything Vinshine currently sells. Bought from him multiple times. I think Al has too.
Tony
They only thing I ever compared them to was the factory LPS supplied by Auralic and I couldn’t tell any difference. Yes they come with DC cables.
Thank you.
since LPS is 24/7 on, buy a good safety one … I had a bad experience with the cheap one … so beware
Which cheap one?
TIA
I made a purchase from a PSA Forum member, awaiting arrival.
Thanks all
TD
