LHY AS8 pro+ has landed
LHY AS8 pro+ has arrived today, just installed it in my system. Will keep the original SFP’s for a couple of weeks running in.
It will be interesting to hear what you think about the improved clock!
Not just a better clock, upgraded and magnetic shielded power supply, internal wiring, clock housing, etc.
Unit is still running in, unfortunately I caught a bad cold last week and my ears are still “closed”.
I imagine it will be on the same level (or slightly exceeds) the SW10 pro, when my ears are open again I will give some findings.
Did someone compare it to the SW10 Pro?
Very happy with the AS8 pro+ in my system, timing and transients have improved, quieter background and separation of instruments and voices is top notch. Soundstage width is simular to the original AS8 but soundstage depth has increased.
Overall the system musicality has improved and is non fatiguing.
Note: running in takes time, turning off the unit now and then helped speeding up the running in. After a restart it would sound noticibly crisper. Now after about two months I don’t hear the difference anymore after a restart
I placed my order for the LHY AS-8 PRO+ yesterday, so incoming soon.
I was very impressed with the older SW-8 using an older Synergistic Research Orange fuse.
The technology of the latest AS-8 PRO+ is quite a bit ahead of the SW-8, so really looking forward to adding this to my Muon-Pro, Grimm MU2 system.
I should have bought one when they had their introductory price. :expressionless_face:
You might also check the upcoming ENO3
The AS8 Pro+ arrived yesterday. I just installed it, so I will not be doing any “critical” listening for at least until Monday, due to break-in and busy schedule. Thus, on repeat of the album: “Talking Hands” by Acoustic Mania. I did notice that the internal/external clock light takes more than a few minutes to light up, which would suggest that when it does, it indicates that the clock has reached minimum operating temperature. Physically, this appears to be a very stout and sturdy, piece of gear with substantial heft, and as mentioned earlier, quite a technical (under the hood) step up from my LHY SW-8 switch. Hurry up and wait!
