Oh, I got it. No more rabbit holes for MU2. Good to know!
Fuse and forget it.
I would like it if Sergei from Stealth could make a MU1 cable. The large connectors on the aftermarket cables can be slightly challenging inside the MU1.
How about a Furutech Lan cat 8 NCF? The connectors are a bit smaller and it’s a fantastic cable. Or mount the small cheap connectors yourself on a piece of high quality cable?
Oooh, please tell us about your cable props.
I cut the cable supports out of the packaging material from Furutech connectors. It’s similar to Sorbothane. A solid foam.
There are several plugs missing their cables.
These are Epluggs crystal filled plugs similar to Furutech’s Clearline.
EPluggs
I thought they were dummy plugs that support the real plugs above.
Here is the best power plug support if you are into that sort of things:
I dunno about that. Hard to beat my wine corks.
Donald, the cable lifters from Aliexpress are the best.
I can now see how you attached your 3M absorber sheet and roughly how far away from the plug. I haven’t tried it on the Dragon yet.
I will only mount a Furutech NCF ice on the one for the Farad power supply, which has a wonderful Furutech FI 09 connection. The Farad instructions specifically state: Use the same plugs for the connection if possible. If it says so there, I guess I have no choice but to mount an NCF Rodium plug.
I always think it’s good when there’s a useful use for something. And if it doesn’t involve any additional costs, all the better.
The isolation devices are ready for possible San Francisco quakes!!
Hi everyone
I received the LHY switch 6 a few weeks ago and I must say that it is an excellent product. More detail, less noise. It replaced a nuprime sw8
Benvenuto Pierluigi!
Grazie Luca,
Just put an SR Pink Fuse in my SW-10. More depth. Realism, detail, smoother - worth it.
How is your Master fuse doing? It should be settled in by now, and I hope your streamer likes it like mine before.
Yes 2 weeks ago I put a Master in Lumin U2 and a Pink in my LPS for Roon Server - they are settled in now - It’s like opening a window in my system - also opened another trap door to a new Rabbit hole haha! I am looking at putting a Master in my Preamp/Processor.
Thank you - your suggestions have all been spot on.
Did you say you had put a Master in your Preamp from your previous set up before Grimm?
Do you recommend? It seems it could have the most profound difference there. Thanks…
