Elk said
jazznut said
Thanks ELK for your commitment, but we saw, normal listeners as well as reviewers have different preferences and experiences.
Of course.
But do try the EQ I suggested. A -1dB or -2dB cut centered around 3kHz with a low Q of 1 or 0.9 has a very different effect than taming a presence peak. If you have not heard this I anticipate you will be very pleased.
As I mentioned, due to the fact, that I use NAS to Jriver to Bridge II and Jriver only allows the DSP Studio with USB connected sources, I can’t use EQ’ing of mids (which I didn’t need in the past).
But due to the fact, that with a 3-band parametric sub + main speaker bass driver options I have 8-10 different adjusting options for bass response, I was able to fit the DS quite perfectly into the room and system in this regard.
Those who know how important the proper playback of the lowest octaves is for overall harmonic structure (incl. mids) can imagine, that if this fits, as well as presence area is quite uncritical i.e. through a ribbon driver, that 80% of a good basis for good sound is done.
After finishing the necessary bass settings due to a quite different (not necessarily less or more generally) bass weight from the DS than before, the proper balance was reached again and the DS turned out to be clearly more accurate in bass response and shape.
So I could imagine, if one has high expectations for a quite perfect sound and tonality, how challenging a change from a possibly very different sounding DAC to the DS could be if one does not have a sub and some add. adjustment options. I count the DS as ideal for real full range sound and quite mighty sounding speakers or setups, as many advantages come with its accuracy and its by trend more lean attunement in bass region and above, as long as one can fit to this accuracy from a possibly different previous setup.
The achievement of this final fitting is also an answer to your question why I finally decided for the DS.
If one achieved this or owns large speakers or has whatever setup where the DS fits in perfectly in bass and mids region from start, those other DAC’s with a clearly richer sound must sound clearly too fat in comparison IMO.
This is not meant to say the DS is difficult to fit into a system, but (depending on the degree of expectation for the result) it can be if one comes from the quite opposite direction.
