I just purchased a REM ADI-2 DAC FS. It comes with a 12 volt 2 amp switch mode power supply and uses up to 24 watts. The DC input jack is marked 9 - 15 volts. However, the manual says it accepts 9.5 to 15 volts. It also says
In case the operating voltage drops below 9.3V the internal power supply of the analog I/Os is switched off…
I was considering a Teddy Pardo 9 volt / 2 Amp LPS as an upgrade, but given the statement in the manual that the analog I/Os will be switched off if the voltage falls below 9.3 volts, I don’t think that any Linear Power Supply rated at 9 volts will work unless they actually output 9.5 volts or more.
Does anyone out there have a Teddy Pardo 9V LPS who can measure the actual voltage output?
Would I be better off to find a 12 Volt LPS instead?
