Hi.
I have an A/V Processor with 5.1 Channel Amp and speakers.
This processor used to A/V and Stereo modes (Stereo with both front speakers (Focal Electra))
The front speakers pleaced towards the center listener chair in some kind of an angle.
Is speaker placement for both A/V and Stereo can be the same ?
In other words : Can the speaker placed for A/V and Stereo the same angle ?
Thanks.
Hi @ronen,
Yes they can and probably should be the same. I have a very similar setup although I have the Focal Sopra No. 2 speakers. I do not change the angle or position of my speakers in any way when switching from music to movies.
Thanks
If your target seating position is the same no change is needed.
Thanks
Its been answered but yes just keep them the same. I have a combo room as well and it works out great.
Hey so do I. But I don’t use a center channel speaker. The L/R do the trick wonderfully and dialogue is fuller.
