Hi, I am looking for the best VPNs that can work properly in PC. Can anyone please suggest some best VPNs for PC?
Welcome to the forum!
I have used NordVPN for a couple of years now. Pricing is fair and performance is good. No noticeable slow downs in web speed.
I also use NordVPN and have been happy with it.
Do VPNs work well with Android Auto if streaming music through a Qobuz or similar streaming service to the vehicle?
Surfshark.
The interface to Android Auto is Bluetooth. You will be fine with the VPN running on your cellular connection.
Thank you everyone for your suggestions. But after searching on Google I came across this post that recommended some VPNs that suitable for use. Actually as I am looking for free VPNs, sorry I forgot to mention here, so I selected Proton VPN.
First I installed Sufrshark, but it did not work perfectly. Whenever I checked my IP address after using Surfshark VPN, it did not change. The same IP address was showing.
Then I installed Proton VPN and amazing, it is nicely working.
I dont know how long days I shall use this VPN for free, let see what happen!
