Hey everyone, Question, I’m looking at buying Tekton speakers that run at 2 ohm consistently, will my M 700’s handle that demand constantly? The manual states “2 ohm stable for musical transients “ to me that sounds like it won’t handle 2 ohm constantly. The speakers considering Pendragon 2 ohm. Thanks
Icepower modules aren’t designed to run into that type of load except for brief periods.
thanks for the advice
Why would you order the 2 ohm version when it is also offered as 4 or 8 ohm depending on whether the woofers are wired in series or parallel?
Perhaps they are used.
