Native DSD On Stellar Strata
Does the Stellar Strata play native DSD via USB, or does it only play DoP?
Thanks!
You should be able to look at the specs on the website or download the manual to check for sure.
It can do either.
Thank you both!
@Baldy, I did check the online specs just now and it does indeed specify DoP via a USB connection:
Much appreciated. I was trying to send a Native DSD signal from my Eversolo-DMP-A6 and it wasn’t playing, so I wanted to make sure of the specs before asking Eversolo to work on the driver.
