I got my new Directstream DAC 24 hours ago. I purchased used but I think I got a brand new unit.
I’ve been using the XLO burn-in track continuously with the amps off.
The Directstream sounds terrible: the images are small, the sound is thin and tinny. Guitars don’t sound like guitars, tambourines don’t sound like tambourines but like high pitched noises. If I didn’t already know it was a tambourine, I would’t be able to tell. Poor instrument separation. Voices are sketchy and indistinct.
My previous dac is the original version of the MSB Power Dac which is vastly better.
Chromcast audio: anyone try with the DS? It’s the size of an Oreo. You can hang it off the toslink input. Needs a USB power supply too. Only $40 so I’ll try no matter what. Seems like a great way to stream internet radio, pandora, etc into the DS. I know this is an audiophile forum but sometimes you just want the choices on the internet easily implement into the big rig. The downside for Apple people, like me, is no airplay and a flakier app. I don’t know it’s digital output but guessing min 16/44 (probably 24/96) like Sonos. Nice, simple and cheap. Anyone in this community try it?
Yes I’ve used it a fair amount but just for Spotify, sq very nice with their Extreme stream, but my MicroRendu now has it so I no longer use use it, even better sq. It’s been very reliable, only connection problem was once when I needed to install new s/w.
