Paul mixing engineer for Octave Records releases?
Hi @Paul
In your latest YouTube video you mention you’re honing your mixing skills.
Is this something you are doing for real Octave Records releases?
Or you are just doing that for fun on the side, and you’ll leave the mixing to the experienced pro’s ?
Will your new Octave Records studio be all in the same building as your engineering or separate buildings?
Thanks!
I asked that question…
Have a blast, Paul!
My experience is it is a steep learning curve, but satisfying. :slight_smile:
Thanks! I don’t follow every corner of the interweb.
Good to know it will be left to the pro’s. I was ‘concerned’ :slight_smile:
