Pin configuration on Stellar M700
Can anyone tell me the Pin Configuration on the M700’s. I brought a pair of Zu XLR’s which are:
Pin-1Ground
Pin-2 Hot Positive
Pin-3 Cold Negative
thanks, Don
This is the standard pin configuration. I am certain the M700 is the same.
Indeed it is. Thanks, Elk.
Thanks Elk
