PMG 512 DAC first impressions
Got the streamer working, just had to enable it in Roon (duh).
Now I’m getting a static snap noise in only the right channel.
I’ll let it run the weekend to break in and see if it goes away otherwise a call to tech support on monday.
Sorry hear hear you are experiencing streamer troubles! Keep us posted.
Alter John Atkinson slammed the MK II with his measurements I would be very surprised if the PMG DAC doesn’t measure very well on his system. Personally,I find that the PMG DAC has blacker backgrounds than the MK II . As you know the less noise there is the blacker the background.
I found that if I run dsd64 through my dac any sync issues (which is supposed to be fixed in the latest batch - they held them up due to this) seem to go away. PSA is sending me back my original with the hardware fix. Right now the latest firmware they send seems to working the best. Only get the issue when swapping between odd ball rates. 88.1 to 192 etc.. but send dsd64 to it, fixes the issue. if only for two seconds of playing. The hardware fix should get rid of that.
Do you know if the hardware fix has been implemented on all outgoing units now? If so, would that already be fixed on @DennyD ‘s unit as well as latest FW?
I mean, his unit should reflect the most recent fixes. If true, there are still problems with HW/FW then. Hmmm
My PMG DAC is will not sync to Roon or Quobuz as well. Ethernet and wireless connections are good and both R and Q recognize the PMG device. You can see it, select it, and a confirming check will appear. After that, the album will play for 10 seconds (no audio) and a Quobuz notice will indicate an error. A few times the album did not abort but always dropped in and out.
The manual is pretty good at setup and troubleshooting, but these re-try’s didn’t help.
I certainly could be missing something. Delia has been helpful. My unit did not have the latest FW.
If you go to the FW screen it will indicate if an upgrade is available, and it easily updates.
More later and open to suggestions.
Interested to hear more about this HW fix.
I beleive all new are getting the wire fix. It’s An increase in length of the ribbon cable between streamer and dac. Simple and they knew about before shipping and were testing it. So I would have to assume all got it.
thanks for the info. You’ve been a great source of first hand knowledge.
The sweet spot for the PMG DAC is DSD256, not to be argumentative with Andreas who knows a hell of a lot more than I do. None the less, our SINAD is -100dB compared to the MKII at -80dB.
Does anyone have a Lumin P1 that may be considering the PMG DAC?
I have the Playback Designs and I can assure you DSD256 sounds better than DSD128. The sound drys up a bit with DSD128 with the exact same recordings compared to DSD256, so I don’t know what they are talking about.
Brian you certainly have earned the right to a beta tester developer’s fee. You have been the one true source regarding issues with the streamer. Saving my coins for a Grimm MU2.
With my credit I had with PSA the price difference even getting a deal on MU2 was almost double. I am very very happy with the sound quality as a combo unit. I am waiting a bit and then compare the pre section compared to my ARC LS28-SE
Interesting. I trust what you’re saying is true, odd that the designer thinks otherwise.
The designer did say that playing back on whatever format it is mastered in sounds best because every processing degrades the sound somewhat. So if the recording is not mastered in DSD128, it may not sound best in DSD128. I believe the recordings I was playing were mastered in DSD256.
Any fixes that you know of for the remote issues?
Not all designers can easily work with what they hear or don’t hear despite the measurements. I run into this problem all the time where the test bench tells me what to expect and the listening room disagrees. I’ve just done this long enough to trust my ears more than my meters.
Thanks, Brian. For sure, all PMG Signature 512s leaving the factory have the longer cable Brian is referring to as well as the remote control variability solved.
In Paul’s ears we trust !
