I use a Shunyata Research Altaira star chassis grounding system for my main components which can improve sound quality and lower background noise. This is connected to an Everest power distributor and to a dedicated 20-amp line to the circuit box.
Which PMG preamp chassis screw is recommended to attach a ground cable to the Altaira?
Edited to say, I see the ground screw location. The actual screw is not labeled or shown on the photo in the owner’s manual.
A set of four Townshend Audio Seismic Isolation Pods under my PMG. Not much more than a boutique fuse in cost, and the improvement is immediate and obvious: more open sound, better definition, bigger soundstage.
I’m using Synergistic Research Pink fuses with wonderful results. Maybe the Master would be better but there’s a limit what I’m willing to spend just for a fuse.
