PMG vs AirLens
Wondering how the streamer in the PMG DAC/Streamer will compare to the Airlens
I was told that the consensus on that has not been determined yet so to me that means they are really close.
It is better by a bit. Noticeable yet not huge, but absolutely noticeable. I suspect it’s because of a lack of external cables and all that.
Hi Paul, your opinion on going straight from PMG dac to upcoming PMG amp vs PMG dac to BHK Pre to PMG amp.
Thanks Paul.
So is the streamer board in the PMG DAC the same as the airlens board, or have you made some changes/improvements?
It is completely different: different platform all built on a small SBC rather than the Convers module we use on the Airlens. Designed and programmed from the ground up in the case of the PMG.
Is there a linear power supply involved?
What is SBC? Google cames back with Subband coding for Bluetooth and that doesn’t sound right for what you would be using.
Single board computer, I’m presuming.
are we talking RPi?
Single Box Computer
Any recent impressions on SQ-differences between the PMG512 and AirLens (coupled with the DS-MK2)?
Thank you.
not sure anyone has really done this. The PMG is an upgraded version intenral, so not sure how adding another box and cable would help.
For DAC PMG sounds better than MK2, so it’s unlikely MK2 plus AirLens will sound close to PMG streamer.
