PS Audio New Wave Phono Convertor replacement
I’ve spent the best part of the weekend trying to get my NPC to talk to my Windows 10 PC, nothing physical has changed but something it last weeks Windows 10 update to 2H02 build 19042.867 has either broken the USB interface or caused a failure in the NPC.
Given the NPC are way out of support, and I’m not interested in buying a used one if the NPC is the problem. What are the alternatives for a phono stage that does A2D and has a line level output?
I use a music hall turntable > NPC > USB to Windows 10 PC and typically record 5-10 albums a week. I don’t use it for listening, typically I just have RCA > AMP out of the NPC.
What are others using now the NPC has met it’s maker?
We had the same issue with USB connected printers. You have to rollback the march 9 update and everything should start working again.
March 9, 2021—KB5000802 (OS Builds 19041.867 and 19042.867)
There is a PS Audio USB driver under Resources > Download Drivers.
I would try installing that first and see if it gets the NPC working again.
You’re going to let windows win that easily? Don’t trash your NPC over a buggy windows update!
Of course I tried the drivers again, and yes I am seriously considering replacing the NPC with something else. I’m of the opinion that the PSAUDIO USB drivers are really the issue.
Rather than get too far off topic here, where I was hoping to hear what alternatives if any there are to the NPC, I’ve posted a response over here NuWave Phono Converter - #258 by 4mc
Depending on your budget you could look at the SweetVinyl Sugarcube SC-2 Mini ($2500) or SC-2 Mini Phono ($3000) available at Music Direct.
https://www.musicdirect.com/Search?searchterm=sweetvinyl&sort=popularity|DESC&page=1&pagesize=24&c1=tab-products&c2=grid
These remove record noise, convert it to digital and record to a USB stick including looking up meta data (album, artist, song titles) and tags the recorded files. I have the older SC-2 (used) coming later this week. All reviews I have read say that the noise removal does not affect the sound quality.
The PS Audio USB drivers were working fine until the Windows update right? So wouldn’t the Windows update be the issue and not the USB drivers?
I can’t be sure if it was last weeks update that broke them, but by the time I rolled back the update, I couldn’t get them to work. The USB cable was plugged into a different USB port or had been plugged into a bunch of ports and install tried, no good either before or after.
The point is, by comparison to the Soundblaster USB drivers, the PS Audio drivers are very fragile. Even the install on a new machine The PS Audio driver doesn’t always detect them and the install process prompts you unplug and plug them back in again. I can’t say if thats an issues with the USB Chipset they use, a software design issue, or something else, but it’s clearly not just a Windows update issue.
Maybe the NPC hardware has failed? Who knows.
Wow, gulp, for that money it better be good. I prefer to do my own editing and cleanup, but it will be fascinating to hear how it works.
I had been considering an McIntosh MP100 MM/MC Phono but am wary of spending too much. Second on my list is the Music Hall pa2.2 MM/MC Phono Preamplifier, which seems like a direct plug replacement for my PS Audio NPC. The only problem, it’s also long in the tooth and I’d hate to buy something going out of support.
I’ve heard a NAD ELECTRONICS NAD - PP 4 and it sounded OK, but the USB output on the front would be weird in my setup, which you can see here. https://markcathcart.com/wp-content/uploads/2021/02/PXL_20210209_194011336-scaled.jpg
That’s a shame, NPC a great kit. I use an older laptop with Win 7 to do my recording so thankfully no issues with USB so far.
Yes, It’s just so frustrating.
I may consider using a dedicated computer and use Windows 7, its a big deal though since the cabinet I already have the desktop computer in is packed. It sits under a 76-inch TV, and the computer uses the TV as a monitor when I’m recording and editing, and is a VPN 24/7 to allow me to stream my own music from home when I’m away. We also use the PC for certain streaming services, so it’s not practical to go back to Windows-7.
I need to think it through, for now I can get by going back to the Soundblaster. I don’t have a tight schedule for digitizing. I did a Hank Crawford double album yesterday with some tweaks I think sounds pretty close. Hence I was open to hearing what others were using.
