PS Audio Noise Harvester Light Not Blinking
So I have 5 PS Audio Noise Harvesters. I noticed that 2 are not blinking. When I take a known blinking Noise Harvester and plug it in an outlet with a non blinking Noise Harvester it starts to do its thing and blink.
Does this mean the 2 Noise Harvesters are not working or is it a bad LED?
Two of my original five Noise Harvesters have died over the years. One partially melted while in the socket. If you suspect one isn’t working or is behaving oddly, get rid of it.
Thanks PB. I’m wondering if there is a warranty?
Our products are warranted for 3 years from date of purchase. We’d be happy to replace the Harvester for you if you’re in the US. If outside you’ll have to speak to your dealer.
Thanks Paul…unfortunately I have them over 3 years.
Did you ever hear any difference with them?
I absolutely hear a difference. I live in NYC and the blue light would blink very often at times.
I had all 5 Harvesters plugged in various outlets in my listening room. Even with only 3 working the noise floor was lower creating more detail and separation.
Contact our service department and ask for Jeremy. Tell him I said it’s ok to replace the broken ones for free despite they are out of warranty.
Thanks so much Paul. That’s very generous of you! I appreciate the outstanding customer service.
Paul
Hi Paul,
I seem to be having the same issue. Got it about four years ago but hardly used them. Recently, when I plugged them in various different wall sockets and Dectet, the led didn’t blink at all.
Kevin suggested to send to your local distributor here in Malaysia and the distributor’s prognosis is that the Noise Harvester is unrepairable.
Is there anything that can be done?
Thanks
Howdy @ericym,
We’re definitely able to help out. Please send an email over to my colleague Travis - he handles our international accounts. You can reach him at Travis@psaudio.com
Unfortunately they cannot be repaired. We typically replace them.
I bought two of them from Music Direct. Both had no light blinky. Sent them back and they sent me two new ones toot sweet. The new ones blinky like crazy. Especially when plugged into the back of my P20, which seemed counter intuitive.
Greetings from Hong Kong! I bought five Noise Harvesters in 2018-Mar (all plugged into the duplexes of my two P20s), and two have already gone kaput. Can I get them replaced at Radar Audio?
I bought two of them. I notice one does not light or blink. In my opinion, if they were a genuinely good product, they would still be made, and they would not fail. I have some power products from many manufacturers, and the poor ones usually last 10 years or so. They have to be pretty poor quality to fail.
I bought a couple of them when they first came out many years ago. They worked fine plugged into the wall and I can definitely hear an improvement in lower noise and clarity back then. Over the years, I have gotten better power conditioners and power cables and I cannot hear any difference these Harvesters make anymore even though they are still blinking normally as before. I believe if you already have good power conditioners and cables, these Noise Harvesters are irrelevant in any more differences. But I still have them in the system out of habit.
I found x3 in storage a few weeks ago. They were still working - blinking like crazy. I chucked them in the bin - literally. NOT because I think they don’t make a difference (though I couldn’t tell), but much rather because of my recent de-cluttering Damascus experience, and the driving need to purge myself. Like pouring 16-yr whiskey down the drain. :wink:
