I am using a mac (running sonoma). I hear no sound when i connect my mac to the stellar gaincell via usb c.
anyone experiencing the same issue
How are you connecting the Mac USB C to the DAC USB B input? Is it with an adapter/adapter cable? What software are you using for music playback?
i am using a Macbook pro M1 from 2021, audio interface are usb c.
My cable is a standard USB B vers Type C (the same cable is working fine between my mac and a Cambridge system that I use in another room).
I can reconize the GCD interface from my MAC.
I got no sound from Roon , Audirvana, Quicktime, VLC.
Hope this clarify
thanks in advance for help.
I mean no soud from GCD.
what is on the GCD display when you play a track ?
