Hello,
are the upgrade kits from PWD among themselves Compatible…
Hello,
I do not understand the question. There are two update kits for PWD to DirectStream, both are identical except for their voltages. One if for 230 volt countries, the other for 120 volt countries. Between the two they are not interchangeable.
He may be asking if all PWD I to PWD II upgrade kits are identical…
And the answer to that, of course, is no, they’re not.
–SSW
Which version is the ???
Uwe said Which version is the ???Sorry picture did not arrive ...
Is Ok, found out what is for a Upgrate putty…
