Thanks.
Use these under my TT platform and work great, looking to fit sets under my DS Dac and BHK pre.
Given they work best within a certain weight tolerance “sweet spot”, which ones are you using given the weight of each unit?
And are you using 3 or 4 footers for either the Dac or the Pre?
Thanks in advance, will guide a buying decision.
