Room Correction Results
Room is 20 ft x 11 emptying across ~ 4 wide x 15 ft hallway into a ~ 10 ft x 9 kitchen. Past the kitchen is a ~ 3 ft wide descending staircase. Beyond that is a ~ 3.5 ft wide open closet comprising most of the length of the long wall to the corner. There are three ~ 2 ft wide bay windows at one end of the short wall, which usually stay closed. A triangular ceiling peaking at 11 ft extends over everything.
Troy Crowe and I haven’t finalized design of the main speakers he’s building for me. But most likely they will resemble these but minus the back loaded bass horn. Speaker System No.2095 – Joseph Crowe
My plan was to build a 3.1 (3.3?) system for DVD and BD movie sound, but designing a center channel speaker that will at least approach the tonality of the mains and won’t block the view of the 65” TV screen looks problematic.
Thus, all this talk about room correction may seem premature. But as all my source material is digital and I’ve yet to own a standalone DAC, I reasoned that if I’m going to spend serious money on one-and since most experts and experienced DIYers all claim that it always sounds way better when the room/system is acoustically and electronically corrected-then a MCH DAC with stereo DAC sound quality and software with a not too arduous learning curve seems to be the sensible investment.
DAC budget is ~ $5.5K. But I don’t mind complaining about the dearth of MCH DAC choices, at least offering more generous output voltages and use of other DAC chips. Markw4 at diyaudio.com and others claim that it’s not just output stages, quiet power supplies and digital filtering schemes which determine overall DAC sound quality. They say AKM chips have at least some sonic advantages over the omnipotent ESS chips. But Mark mentioned last year that post-COVID supply chains and other factors will postpone an eventual swing towards AKM chips for some years.
Yes, as I’ve read from those at gearspace forum, the first step should be to acoustically improve the room. But IIRC, they also said that the best way to do that is to take mic measurements of the room and use the saved WAV files and analytical and software (which?) to determine the room’s problems (ring modes?) and their locations-and thereby know what acoustical materials to use and where to place them.
Yes? If so, then that’s why I have been asking here about MCH DAC and room correction software comparisons.
Instead, the midrange horn will sit atop these Altec midwoofers.
And my three Jim Salk built Rythmik F12 subs.
Anthem takes care of me with my Theater setup. The DACs in the Anthem bring me no heartache. ARC is swell. It’s a separate room, attached to my main room. I don’t like to mix the streams between pure audio and theater audio. My theater system is ancient and yet up to date. Still 5.1 though. One seat.
Of potential interest:
Or, by an older used Anthem AVM 50v pre/pro just to employ ARC.
The newer Anthems don’t have balanced analogue inputs, which I like to use with my DS Sr. DAC.
Interesting setup. How will the 3 subs be connected? all 3 using high level? Did Jim include a high level in those subs? I have a Rythmik G25HP and it does not have that ability. Just curious with a multichannel dac would you hook up those subs? 1 output and split 3 ways? No way to do proper room correction that way. If two were used with high level (left and right) and one was LFE you could do that but only if they support that. If you really want to leverage 3 subs in different spots in the room you need a miniDSP 2x4 and REW to tune. Or get an AV processor that does that, and not all do more than 2 as its not easy. My AVM70 only does 2, the 90 does 4. Phase matching and all that is not easy. Marantz AV10 is another good choice and it does Dirac.
You sound like a DIY type of guy. The miniDSP may be the easiest way to go with the DAC you pick. BASS is the hardest to get done right, with some room treatments for the mid range you may be good with just that. Experiment, try and try again. REW can be your friend with that.
Prior to any room correction, I wonder which would tend to sound better: Merging Hapi or Anthem AVM90 or LYNGDORF MP-40 2.1
