Hello,
I have been happily using the SGCD for a few years but now have need for an extra analog input, My question is this: According to the manual, input 1 is used for either an XLR or a RCA connection. Can I connect both to input 1, the RCA to one source and the XLR to another and use input 1 as long as one of the sources is off? I would rather not try it if it will damage something.
Thanks for any help you can give.
Harry
