Speaker cables causing issues
I have an Innersound E300 powering a pair of Acoustat Monitor 4’s, with Kimber kable12tc. I was listening to some music, and all of the sudden I had no sound! The Innersound power light was still on. I turned it off, and the amp was very hot! Luckly the fuses blew in my Acoustats. AI says the Kimber Kable is the culprit! Could this be true? AI says its because of the Kimbers low impedance? Ive been looking at used cable on ebay If I have to get new cable. Unfortunately I’m a poor audiophile, and I dont want to buy some cheap scrappy cable! Lol
Thanks, Jake
I assume you’ve used this setup for quite a while and it has worked fine. If true, I don’t see how speaker cables would suddenly become the problem. I am glad you asked people this on the forum and are suspicious of the answer AI gave you. Those Kimbers have 8 AWG per leg and can handle high current. Low impedance of the cables would not cause overheating of the amp.
I don’t know anything about your type of speakers, but Speaker Load Impedance is what can cause overheating. If you connect speakers with an impedance that is too low for your amplifier you can get trouble. Perhaps you could look into that and someone familiar with your type of speakers /amp combo can elaborate.
Welcome!
My Innersound amp was designed by Roger Sanders, built by Coda, for Electrostatic and flat panel speakers. it can handle pretty much any speaker you throw at it. Once I sell some gear I plan on having Mike Burgert of Acoustat fame look at my amp. AI keeps saying since my speakers can dip to 2ohms no twisted or flat speaker cable. Never heard of speaker cable causing an issue with an amp.
My guess is something failed inside the amp. You have the right idea to have someone look at the amp.
Yeah, out of curiosity I looked up the amp and speakers after I had posted. Those seem to be a perfect fit for one another. I think you are on the right track with having your amps looked at - you are wise to be suspicious of speaker cables being the cause of the issues. They’ve worked well for quite some time I assume?
Yea I’ve used the kimber for a while, it looks like if it were the cable that it would have acted up way before then. I popped the top on the Innersound and what bits I can see, I dont see any toasty parts or smell anything. But I guess something can go bad, and you can’t tell.
IIRC doesn’t the Acoustat have some sort of interface box? If so, is it possible something has aged out in there? Although I’ll admit affecting both boxes at the same time would seem unlikely.
The Blue Medallion interfaces were sent out to Mike Burgert, they are better than new.
I have no idea what AI you asked or the exact question but the Kimber Kable could NOT be the problem. I mean you could wire your speakers to your amplifier with bars of solid silver and that still wouldn’t cause a problem and you won’t get much lower impedance than that. There’s something wrong with your amplifier I’m afraid.
Here’s what Roger Sanders says about speaker cable. ​PHYSICS OVER HYPE (CORE PHILOSOPHY)
​Wire Directionality: Wire is not directional and does not have “magnetic polarity.” Cables with signal flow arrows operate outside established science.
​Signal Degradation: Cables cannot add detail, warmth, or improve sound beyond what the electrical signal provides. They can only degrade the signal if poorly designed.
​Line-Level Interconnects: All properly shielded, well-designed line-level interconnect cables sound identical because they carry negligible current. Connector build quality matters far more than exotic metal alloys.
​SPEAKER CABLES & ELECTRICAL PROPERTIES
Because speaker cables carry high current into dynamic or electrostatic loads, performance depends on three electrical parameters:
​A. Resistance (Impedance)
​Must be kept as low as possible to prevent power loss and maintain high amplifier damping factors.
​Heavier gauge wire is essential for longer cable runs.
​B. Inductance
​High inductance acts as a low-pass filter, rolling off high frequencies.
​Placing positive and negative conductors close together minimizes inductance.
​C. Capacitance
​Highly critical when driving Electrostatic Loudspeakers (ESLs), which are capacitive loads.
​Excessive cable capacitance increases amplifier stress and can cause amplifier instability or oscillation.
​Widening space between conductors reduces capacitance, but increases inductance—creating an engineering trade-off.
​SANDERS’ CABLE DESIGN SOLUTIONS
​Coaxial Geometry: Using a coaxial layout (one conductor inside the other) minimizes both inductance and capacitance simultaneously.
​ESL Cables: Spiral-winding coaxial conductors in opposite directions cancels inductance while maintaining safe capacitance levels for electrostatic panels.
​Woofer / Bass Cables: Dual coaxial conductor pairs drop impedance and resistance to near-zero levels, handling heavy current demands without choking bass dynamics.
​KEY TAKEAWAYS FOR AUDIO SETUPS
​Avoid Overpriced Cables: Do not waste money on boutique cables with inflated price tags or passive inline filter boxes.
​Focus on Terminations: Choose durable, corrosion-resistant connectors (gold-plated copper/brass) that maintain tight contact over time.
​Match Cable to Load: Prioritize low resistance, low inductance, and low capacitance when driving difficult loads like ESLs or sub-4-ohm speakers.
I’d take Sanders’ cable advice over any and all AI slop. Thanks for sharing this.
This one I disagree with. I have proven to myself it is not true. Most of the other statements ring true.
I purchased a few pairs of RCA interconnects and speaker cable from Roger (after a couple of lengthy telephone calls) from Roger almost 15 years ago or so. This was back when my speakers were QUAD 989. As I remember they were Mogami cables with Vampire Wire connectors. They were okay but not anything I didn’t end up replacing within a year with the usual suspects such as Shunyata.
It sounds like he’s saying “here are the things that I believe. Beyond that my mind is closed”.
Ron, It sounds to me like he’s saying “here are the things that matter most. Beyond that things are of lesser importance.”
Re-read his comments on line-level interconnects.
Regarding ESL speakers and cable the Iconoclast TPC can be an excellent match. Check on the Kimber capacitance value, it shouldn’t be a concern. It has been ages since I used Kimber Kables and that was with Totem Model 1 speakers. BTW Iconoclast has a liberal trial program.
EDIT:
Kimber 12TC 150pF per foot
Iconoclast 45pF per foot
The effect will depend on the cable run length.
I can attest anecdotally that when I had QUAD ESL-989 speakers my two favorite speaker cables were Nordost Rev II and XLO Signature 5.3. This was 15 years ago so admittedly dated and I only had so much to spend.
Anyway, the capacitance for the Red Dawn was 7pF per foot and XLO merely states “ultra-low capacitance.”
As I recall the XLO was a nice cable.
I preferred Discovery and Nirvana cables with my Genesis V speakers. Still have a full loom of each in a closet somewhere, with a Straightwire loom.
