Speaker cables causing issues
THERE IS NO SUCH THING AS A LOW “IMPEDANCE” SPEAKER CABLE. There are low resistance, but not low impedance as the Vp drops with frequency the impedance goes UP, a LOT. The resistive component is LOW (the wire DCR) but the reactance vector is HIGH as frequency drops. Impedance is the vector math combining the real and imaginary vectors, and it is mostly reactive, hence the high impedance isn’t very 'resistive. Our IC and speaker cable is more and more capacitive vector impedance magnitude as frequency drops. This is your problem.
Your amplifier drives the total reactive load, cable+speaker. The 12TC has high capacitance,150 pf/foot and the suggestion that the capacitance changes with frequency is wrong, measures at 1KHz the capacitance is the same through to RF. What changes is the capacitive reactance where each frequency sees the capacitance differently; Xc= 1/ 2pie*F*C. As frequency goes up, the capacitance looks like a short, not a reactance. The majority of the POWER sent to the speaker is below 100Hz, exactly where the reactance drives the amp nuts. It need a RESISTIVE component to dissipate POWER, as reactance can’t use power, only change the PHASE, or react to it in phase. Amps hate that stored energy.
The 12TC is just a bad design for this kind of speaker, and your amplifier. Some amps will tolerate the reactive load, but you don’t have that amp! Cheaper to change the cable.
For unique and highly reactive speakers like acoustats, adding even more reactance with the cable is a problem for the amplifier that can oscillate into higher reactive loads. To do a quick cheap experiment, use any zip cord style, 14 AWG is fine, speaker cable which will have far, far lower capacitance per equal length. Odds are your amps will run fine. If so, shop for a low capacitance speaker cable (less than 100 pf/foot).
Oh, IC cable do indeed respond to R,L and C changes, even with voltage transfer function into high impedance. Time based issue are still there.
Best, Galen Gareis
I figured you chimed in in at some point, Galen. :grinning_face_with_smiling_eyes:
The grade-school level post is too deep for me to understanding clearly, especially a second shot of whisky already made me fuzzy (normally just one, but Balantine’s 21 yrs is too good). However, it is an excellent idea using a pair of zip cords to tryout, and finding out if SC was the cause.:wine_glass:
I remember years ago someone lent me a pair of thin “best cable”, and it made my BAT amp almost smoking! From then on I only use water-hose grade SC.
Well, what the amplifier wants is DCR! Not less to be honest. It helps offset the capacitance. To use low DCR, you need to decrease the capacitance. Amplifiers will want to oscillate into the right reactive load. Amps are just oscillators made wrong. Simple zip cord like 1313A has low capacitance, not necessarily the best sound quality, but the most stable situation to use as an evaluation and isolate the problem.
Best, Galen
Maybe I missed it in the above posts, but I didn’t see anybody stating capacitance changes with frequency. However, the net resistance, inductance or capacitance does vary directly with cable length. I wouldn’t go so far as to say the Kimber 12TC is a bad design, but with its high capacitance, low inductance, and low resistance it is a poor match with a reactive load (capacitance in the case of the Acoustat Monitor 4), as Galen states (Iconoclast Designer). His suggestion to experiment with zip cord is solid and inexpensive. If that solves it give his Iconoclast TPC cable a shot. The Kimber 12TC is a well regarded cable and likely would sell for a fair price on the used market to offset the cost of a cable change. Note any upgrade for the Acoustats should focus on balancing low inductance and capacitance. Note, there will be a trade-off when trying to lower both simultaneously.
Kimber 12TC specifications
Some food for thought from Nelson Pass based on testing done with speaker cables circa 1980. The physics hasn’t changed, but cable design has come a long way.
Nelson Pass White Paper
Just to put my igorance of things electrical on full display: I thought you couldn’t simultaneously lower both inductance and capacitance at the same time because they are inversely related.
I’m missing the point of what you’re saying, aren’t I?
OK, from AI that makes less spelling errors than I do;
The physical capacitance value of an ideal capacitor does not change with frequency; it is strictly determined by physical dimensions (plate area, plate separation, and dielectric material). However, the impedance and reactance of a capacitor change significantly as frequency increases, and real-world capacitors display non-ideal frequency behavior due to internal parasitic components. [1, 2]
And yes, you CAN indeed lower inductance with capacitance but you need to use electromagnetic field cancellation and plate area variation to do it. The bonded pair used in ICONOCLAST has 0.126uH/foot inductance. But in the finished cable it is only 0.08uH/foot. To keep capacitance in check, the weave design makes sure every bonded pair is evenly separated uniformly along the cable’s length, lowering the absolute total bulk capacitance, which would be far, far higher if that was not done.
You can get low capaitance with low inductance but it isn’t simple. I intended ICONOCLAST to be an easy cable for amps to drive with any speaker (I used them on my CLX stats). To do that, we need to mitigate L and C when Vp issues are addressed (see the design papers). To address Vp issues, I used the insulated loop DCR as the primary variable as DCR is most inert. The equations suggest capacitance could also be used, but that’s a reactance and I don’t want to raise that above the lowest possible value in the root design.
Thank you – so it’s possible. I appreciate your taking the time to educate me.
Not to confuse you, but L and C aredefinitley “opposite” forces. You can keep C in check while reducing L, but you are correct in that C WILL increase. Notice in my example, even though I got L to 0.08uH/foot, down from 0.126uH/foot, the C value of the bonded pair was ~12.5 pF/foot and went UP (opposite direction the L) to 45 pF/foot . You are correct that L and C go opposite directions, my point was that you can keep them in a much narrower range than if you ignore mitigating designs. As one changes, the other does to in the opposite direction, but the AMOUNT is design dependant.
Best, Galen
Thanks for the further clarification. The way you’ve explained it I actually think I understand what you mean. There ain’t no such thing as a free lunch. But you add that you can bring down the price on what you do have to pay for. And I meant the price in terms of performance to state the obvious.
