Sprout Pre-Out
I am planing on used my Sprout like a Pre-Amp with a Audioquest Mini to RCA Cable, some one try this before or some one used the Output for a Subwoofer or Amp ???
THK
KS
Yes, the line out on Sprout works fine for this.
Paul you was right, I know Emotiva is not the best Amplifier but is good and with the Sprout do a great Job :) IMG_3004.JPGIMG_3009.JPGIMG_3010.JPG
Very naive question - what kind of cable would I use to hook the Sprout up to a Power Amp? An Audioquest Mini to RCA Cable?
Thanks!
That’s not naive at all. Great question and yes, the Audioquest mini to RCA would be perfect.
Can I bi- amp as well?
