Stellar Regenerator
You Betcha. We have one set aside for you to pick up tomorrow. (4/5/2019)
Ooohh (rubs hands together and licks lips) ; )
You know you have Issues when you get excited about a Power Device. Is there a 12-Step Program for that?
Crap sync on the audio on this, but:
There is, actually. Step one is to give me all your gear. You must remove the temptation from your life :stuck_out_tongue:
Oh - but I wouldn’t want to be your Enabler, bud😝
@jamesh : quick question
I’m using the P3, as suggest connect the M700 to HC outlets, these HC outlets are just filtering high current, pass by the fuse, so the output voltage still being regulated for stable at 100/120/230V ? or just same as input and can be vary?
If the toggle in the back is set for regen, then they act like the other outlets and are being regenerated and regulated. If the toggle is set to HC, then it is acting as a conditioner. It will still be voltage specific no matter what.
Thanks @jamesh for the info
