Does anyone have any experience or feedback adding super tweeters to any Aspen series speakers? Presently enjoying the FR5’s on stands in a 13’x25’ room w/o subs. Ceiling and wall acoustic treatment is decent but soundstage depth is lacking some. instrument spotlighting is impressive with m700 monoblocks and a tube preamp, but I am hoping to add more holography and depth to the experience. speakers are 28" from front wall, 36" from side walls and 7 feet apart. listening position is 8 feet away on a couch centered between the two speakers.
I would add a subwoofer and move the FR5’s further out than 28"
I was thinking the next move would be to add two subs, would love to add two foundry 12’s but probably will have to settle for two svs micros right now. i can move the speakers out maybe 4" forward. gik acoustics 4" thick panels behind speakers and hifi gear
Someone replied to your post.
| adifferentpaul Regular
May 16 |
Visit Topic or reply to this email to respond.
To unsubscribe from these emails, click here.
Will Ouweleen
Vintner
O-Neh-Da ®️ Vineyard Est. 1872
Celebrating 154 years of Natural Finger Lakes Wine Production 1872-2026!
Makers of:
O-Neh-Da ®️Authentic Sacramental Wines
O-Neh-Da ®️Vineyard Natural Premium Finger Lakes Vinifera Wines
Will@onehda.com
Direct Cell: 585.734.7324
I would call PS Audio and ask to speak with Caleb regarding F12’s and not go with SVS.
I’d re-think the acoustic treatments looking for where you may have inadvertently over dampened the room.
will do! sorta’ by accident most of my rig is now ps audio gear…do appreciate all they bring us.
May 16 |
i used a moderate hand between absorption and diffusion for sure. thank you.
| Palouse
May 16 |
I 2nd the Suggestion above of F12s for your set up… ![]()
Do you have any side wall first reflection treatment btw - and what about toe in? I bet the first helps most, in this case
I do have side and wall first reflection panels and the speakers are toed in 10-15 degrees…
| Job_Jalink
May 18 |
Will Ouweleen
Vintner
Makers of:
Will@onehda.com
Thanks Gary. They are now 36” from the front wall (as far as the W.A.F. will allow) and are 7.5’ apart (also W.A.F. And sidewall limitations)
| Audioholic
May 18 |
Moving the speakers further out from the front wall will improve image depth. I would also try moving them further apart then increase toe in, which will increase image width.
Will Ouweleen
Vintner
Makers of:
Will@onehda.com
Did these ajustements work out for you?
Still tweaking. Super tweeters arrive Tuesday. Stay tuned
| Job_Jalink
May 19 |
Will Ouweleen
Vintner
Makers of:
Will@onehda.com
