Symptoms of disabled capacitor?
What to look for when capacitor(s) decline?
Electrolytic Capacitors will change value and likely start to ooze (leak) fluid which sucks and the cleanup is usually harder than the actual Capacitor replacement.
I haven’t ever seen Polypropylene Capacitors leak or change value. Same for the Mylar Caps.
Also a cheap LCR meter will help provided the Cap is not in Paralell with something else in the circuit.
My 2 cents…Others may want to chime in and correct me or add better suggestions.
thanks, I should have focused on what I meant…sound qualities
I’ve heard that electrolytic capacitor have a life expectancy of about 20 years.
At 20y/o they should be replaced with something of the same value.
RE: sound quality degradation with electrolytic capacitors in a power amplifier, the capacitance value will slowly decrease which reduces the HV bus filtering. You may notice a less defined quality to the bass especially as that usually requires the most power from the amplifier. If the HV bus sags due to lowered filter capacitance the voltage and current delivered to the speaker will reduce softening the response.
Also, that 20 year suggestion above is a good general rule. I leave my amps on 24/7 which should increase capacitor life because they are not charging and discharging each time you power cycle. You also don’t have to worry about capacitor ā€œreformingā€ as you would if you leave your amp off for a long time.
Capacitor degradation is gradual, and difficult to detect. Akin to a frog in a pot of water being brought to a boil.
Wait, do you mean like rectal bleeding? A lisp? Warts?
I don’t think failed capacitors do any of that.
