So this is the ‘Final Report’ for this series of experiments.
It took quite a while to finish this experiment, longer than I figured it would take…
So to review, I’ve added WA-Q chips to the entire ac power distribution system from the 2) ac mains feeding the main breakers in my panel.
All the way to the 2 transformers in the Mojo amp including the fuse chips and synergistic fuses. And the romex feed from the dedicated breaker also has chips wrapped around it, in a couple of places.
These last few tweaks required an ever increasing number of hours before coming into ‘full focus’. This last round of adding the final set of chips has taken nearly 1khrs. to reach its peak. And as I write this I’m just passing 900 hrs on the transformer chips. Willie Nelson (Stardust) at 88.2 sounds mighty fine…
The thing that ‘sticks out’ the most about taking all this time is, the overall SQ is wonderful even though it takes a while to reach the sought after 100%+. And the degradation in between the last 100% and the new 100% is no where near as bad as the past swirling into the toilet experiences. Which means that while these incremental increases are taking longer to settle in, the overall SQ is steadily rising and the degree of awful sounding periods between are not as bad.
And these past few additions while seemingly adding even smaller portions of an incremental effect are pushing the previous 100% to 105-115% each time. IOW the last performance peak keeps getting bumped ever higher as the latest tweak fully settles in.
Which is what one would hope to have happen assuming that all of the tweaks compliment each other, and are indeed improvements and not just change for changes sake.
And the set of terms I used to describe the high water mark have also expanded to include new terms, focus and holographic.
I touched upon focus in my previous post, but these past few tweaks have driven that point home for me. I can hear various portions of the frequency spectrum loose focus while other portions gain it. And they seem to swap back and forth as the entirety of the whole presentation continues to improve. For instance the bass now has tonality, which means I can hear the bass notes, as notes and not just low freq whumps or thuds or rumbles. But during the settling in process the upper mids can get pinched and a bit ‘scratchy’ or hard edged. Then these 2 ends will swap and the mids and up, become enticing while the bass goes a bit flat and looses coupling. Only to have the focus come back in a little different portion of the audio spectrum, and on and on. All in keeping with the moiré pattern idea as a ‘guide’ to help explain this progression.
Then there is the term holographic that sprang forth due to the solidification, with precision, of the sonic image. And its not just a 3d image hanging in 3d space. There is this harmonic convergence thing, where not only is the generated acoustic energy well coupled to each voice but for example it yields being able to hear such things as back up or background vocals, each as a separate and distinct voice unto themselves, and in the bass where the rich harmonic resonances when properly coupled to their parent become ‘whole’ musical voices not just low frequency thrills and ‘effects’.
When the entire ‘soundstage’ is plainly evident and each voice is musical with its own musical contribution, and not just in 3d space, but is also in a precise time synch with itself, this results in all of the attributes I’ve listed in my previous posts, including gaining a holographic precision to the entire experience.
So now as I finish up this report and I’ve passed the 1050hr mark, the Listener Fatigue Factor has also dropped way off and the dynamic range as seemingly widened as a result as well.
Overall I’d say this series of tweaks are the single most successful set of ‘enhancements’ I’ve made, mostly due to my previously implemented improvements and these latest upgrades are ‘compatible’ and mutually reinforcing.
JJ
