Theoretica Applied Physics BACCH
Thanks Somppsa. I think the Bacch DSP is really a sea change in a way to appreciate recordings. Sure my system still sounds welcoming and wonderful without it. But the realism and an abcence of smearing caused by our listening space disappears. The dynamics and realism really jumps out as is how the recording was.
Now I know what my speaker designer Roger Russell stated about his experiences with my XR290 sounded like in the anechoic chamber whhen he was developing the design. He mentioned his last design the IDS-25 brought him back to what he heardwith the XR290 in the chamber while at McIntosh. There is absolutely a sense of everything with a sense of depth and space.nothing is obscured and images everywhere in the room.
Everything you read about the Bacch is believed upon first listen. I hope you can experience it it is a no brainer upgrade for anyones system with the tiered cost structure. Especially at the Macintosh computer levels. I hope you can experience it and find a way to try it in your system.
Thanks. It has been a fun four years a journey of rediscovery of what HiFi can besharing with others like minded and not. Best forum for this hobby.
Thanks Al. Hopefully the cable raising is a lasting upgrade. Thanks for helping me enjoy my slice of cake following your experiences, recommendations and rabbit adventures.
Happy cake day @Vmax Darrell!
Thanks Vern. I will probably never rest. At least not until I try disabling this Bacch4Mac Mini’s SMPS. Always when I stop and listen i manage to hear something i think can be improve or think of an area whose design begs for another adjustment adventure. So far there’s been plenty of individuals here to give me inspiration and ideas to try next. So passing on my improvements that move the needle helps fuel the passion for better listening.
Happy cake Day! Now DSP tweaking, go man go.
Thanks. I my have to rename myself 2muchgear2&muchless$ pretty soon if I hang out here longer. My wife is starting to ask when do I sell some.
Sorry for your cable lose.
Thank you Paul!
My stack of boxes in the basement and gear that’s not in current use is starting to get embarrassing :flushed:
Does this gizmo work with headphones?
Bacch4Mac Audiophile+ does as extra add on see table at bottom of this URL
The adio and dio also has add in.
I see it. Thanks
Sorry to hear that, Al! Even if I suppose you have one or two cables as spare there…
I am guessing that the terms “Friends” and “Family” caught his fancy; and so, he prefers that payment method.
I run my my cables across the floor and up to the components; thought, you should run your cables across your ceiling, down to your components. lol
Happy Cake Day @Vmax
Thanks and good day to you!
I repaired the cable. I cut out the bad length, stripped the wires, soldered, heat shrinked, (Twice) and plugged the cable in. The Commander refuses to acknowledge power. Sigh.
But the BACCH-SP adio works swell as a Preamp.
I guess I need to drive my gear to Chicago. Boo Hiss.
Do you have to bring the Commander to Kyomi?
