I did some searching in the forum posts, but couldn’t find an answer. I think it’s possible to connect an Apple TV 4K to a Sprout100 using Airplay. Does the Sprout100 use Airplay 1 or 2?
I hope it uses Airplay 1 only, because then (if I’m right) the Apple TV will output 44/16 uncompressed audio. If, on the other hand, the Sprout uses Airplay 2, the Apple TV will send lossy AAC audio…
Best regards,
Wim
