Timezone Power Play
Hi,
I would really appreciate if someone would tell me how to apply a timezone change so that statistics data I view in Power Play reflects the local time at the my location.
Regards
Markus
I believe it is tied to the time setting you have chosen for your profile on the forum. Mine displays correctly.
Go to Profile (upper right of this page) -> options -> display options and choose your time zone.
Thank you for the reply. Unfortunately, my timezone settings are correct in the profile. However powerplay shows the incorrect time.
I have managed to find a solution: Go to scheduled in powerplay. There one can choose a timezone.
Not exactly obvious…
Hmm . . .
I do not have any other explanation as to why the timezone is correct for me. Perhaps someone knows.
