TSS Two Chassis Super DAC
I don’t think he is ignored. For most people here TOSLink does not offer enough bandwidth. I know I would be using it if it supported DS128…
I totally accept that reasoning for an individual case, especially if you’re not lucky enough to get a DS that supports up to 192kHz on the optical input. Is it really so though that “most people here” have libraries with DSD128? I think I have like three tracks that I have toyed with via USB.
@tedsmith I see you typing, and realise I may have made more work for you with that question by not acknowledging the completely different clocking scenario. I understand that the clock which drives the downstream flow of data is itself generated by the Analog box and sent up the other optical cable to the Digital box. This avoids the biggest flaw of SPDIF, namely the need to adapt the DAC clock to the incoming data rate.
I use HQPlayer and upsample all PCM and DSD to DSD128. Yes, it sounds better than letting the DirectStream do it all…
No, there is no implicit or explicit bit clock over the optical cable, but the sending and receiving clocks are isochronous, so simply sending 6 ones followed by 6 zeros allows aligning on the 1/0 transition, after alignment it will remain in sync as long as the data is zero/one balanced over a reasonable time frame. The two channels of DSD data are sent differentially so there are six more bits for lower rate data and zero balancing. The up going clock is similar but at one fourth the master clock rate and hence can have about two bits of payload (one bit if zero/one balanced, but two bits now and then :slight_smile: )
For more detail, it’s something like what a SCAN921023 chip does.
Bootstrapping the FPGA to sync off the upcoming clock when it’s there and running off of a local clock when it isn’t is fun.
Since the length of the optical cable isn’t known, the FPGA has to phase align the data to the analog well enough for the receiver to sample mid bit.
Ah. I’ve recently started doing integer up sampling of PCM via Roon. I have to admit I’m enjoying that more than the built in algorithm… at least for now.
Another factor here might be how few ‘serious’ audio devices (such as servers and streamers) offer optical output… Most manufacturers, and consumers, seem to assume the toslink use case is TVs/DVD players and that’s it. Even devices intended to provide lots of outputs (in my case an Antipodes P2 after the EX) only offer electrical (AES, HDMI, etc) but no optical.
I’m not aware of any implementations that gang up optical connections (as dCS, PS Audio, and others do with 2x AES and as Chord do with 2 Coaxial) to support high bit rates. This would seem to offer the best of both worlds – complete isolation from electrical noise, and bandwidth – using a two-connector system that has been engineered and implemented on various over various other transport layers.
Notwithstanding Ted’s proprietary interface between TSSA and TSSB, why is no one doing this?
Sure. Another factor is that the optical implementations often suck on the receiving device so even though you get no upstream electrical noise, the circuitry controlling the optical circuit on the receiving end generates noise on its own.
I guess if we’re doing TSS FLAs then TSSA and TSSD would make more sense.
EMM Labs uses a special optical connection between their DACs, players, and streamer that has comparable bandwidth to USB. It might use I2S or some proprietary format. They sound really good. I wish other manufacturers would go this way, you don’t even need to double up the cables, one fiber optic is enough. Unfortunately, there is still a lot of myth pedaling about the perfect sound of ethernet etc. (DCS), which is clearly inferior to optical. What Ted is doing is smart.
I saw somewhere in a Hong Kong-based forum that says PS Audio is gonna release a new DAC that will replace Directstream soon?
Read all about it and get updates here:
Ted’s two chassis DAC probably won’t be out until 2022. I’m hopeful we roll out with the DSD MKII this summer.
Is there a possibility that the DSD MKII would have a built in ethernet bridge?
No internal Bridge this time. The streaming function, or “Bridge III” will be housed in a separate chassis. One of the bottle necks for the Bridge II was its power supply. We’re excited about upgrading the power supply and having it in a separate chassis. This will help the sound quality immensely!
Sounds cool. Looking forward to it. Is there any more information released on it?
Still too early for me to say any “for sures.”
Will the BIII be able to pass better than DSD64 to the DAC via I2S?
Much too early to have these types of details known for sure.
I would advice to compare a “run of the mill” HDMI cable with one of the better AUDIOQUESTs for instance. You will be surprised. AUDIOQUEST adresses jitter. Watch a small part of a movie on Bluray and watch again…completely relaxed - and wait what happens. :upside_down_face:
