Tube Recommendations for the BHK Mono & Pre
I’m sure that this is a much discussed topic with a range of opinions. I have had a pair of BHK mono amps and the BHK preamp for a few years and have never changed the tubes.
Two questions:
  1. Should I change them?
  2. If so, what should I replace them with? I know PS Audio sells replacements - are those the ones to get or are there others that people really love?
Thanks in advance,
David
If you search “tube rolling” here, you’ll be kept busy for weeks
I think the recommendations is once a year or every 10,000 hours I thought I heard or read that somewhere on the forums. As far as what tubes? Like what RonP said tube rolling thread and a couple days to read it.
https://forum.psaudio.com/search?expanded=true&q=Tube%20roll
