I’m unable to play DSD using minimserver with minim streamer. Does any one is playing DSD with minimserver? Please help
oll said I'm unable to play DSD using minimserver with minim streamer. Does any one is playing DSD with minimserver? Please helpHave you set up Minimserver to transcode to DoPWAV?
Yes Frode I did but It was still no play until I erased the play list and recreated in bubbleupnp and now is playing, thanks any way.
Oll, you also use BubbleUPnP? I’ve been having trouble with the last couple of versions on my Android. I create a Playlist, but the app will not automatically play the next song in the Playlist. I have to manually advance to the next song. No matter how many songs I have in a Playlist it will only play one at a time. Any ideas?
tony22 said Oll, you also use BubbleUPnP? I've been having trouble with the last couple of versions on my Android. I create a Playlist, but the app will not automatically play the next song in the Playlist. I have to manually advance to the next song. No matter how many songs I have in a Playlist it will only play one at a time. Any ideas?
Yes I use the free ver. and got this problem only if the tablet go into standby. It play ok if it is on with the display active. Maybe is a setting.
