A Frind recommended me to add Under and over voltage monitoring device in my house main fuse box.
http://www.uriel-shay.com/media/upload/files/564006.pdf
Can it be a solution for mains problems and Without Negative sound influence ?
Thank you.
Thank you.
Once you have the information from the monitor, what will you do with it?
BadaBoom!
It’s not a monitor results.
You can adjust preferences for best protection as you think
I don’t know if any of you were aware of a company called Whisker labs. It has a device called ting that you plug into any outlet in your abode that monitors your house for any unusual issues with the electricity that may cause a fire. It now will have the ability to monitor the thd on the electrical grid. They charge about $52 per year to monitor voltage coming into the house and monitor any issues you may have and will contact you and also the electric company( if warranted) to address a serious electrical issue. Some insurance companies also will give you a discount if you install the ting device in your house.
It also has a ios iphone/ipad app that monitors voltage in real time.
I have attached some screen shots of information that the app provides,
Seems brilliant, thanks.
It also mails you a weekly report
