I did some more checking, and if I understand correctly you are dependent on a computer that host the Roon Server.
In other words, pretty much a deal breaker to me. I imagined an embedded version… ![]()
Also, no UPnP/DLNA. No bridge! Not sure how much work they want to put into it either. I like the idea but love using my bridge.
Edit: Can’t wait for Bridge II!!! Been following the ups and downs of getting gapless to work via a network connection on this board for years.
Gapless has been working nicely since early on with B2.
Paul McGowan said I can tell you one thing we are committed to - and hopefully this will happen if the software gods are kind - Roon. Roon is the new Sooloos music management system and we are using it here at the Munich show and I am here to tell you it's freaking awesome!!! This is the answer boys.We’ve been waiting for the perfect interface to our music collections? Well Roon is it! Wow. More later, I am in the middle of it all but jhaving a killer time using it.
Does this mean we need to pay for roon as well as the bridge?
stevem2 said Gapless has been working nicely since early on with B2.That's what I understand and am very glad that's the case. However, until I can buy one, it's still vapor to me.
I know that Roon is not planning to support DLNA so that appears to mean some interface development on the Bridge 2. Is this a major effort or do you expect it to be fairly quick ( if there is such a thing in software development
Cheers magicknow
Green Machine saidPS - anyone got Tidal to work with Chrome + MacBook Pro or OS X Yosemite + DStream DAC ??
magicknow said Paul what have you been able to discover about the work involved to make Roon and Bridge 2 play together? I know that Roon is not planning to support DLNA so that appears to mean some interface development on the Bridge 2.I am curious about this also. I've read as much as I can about Roon. Without UPnP/DLNA support, I can't understand why one would use the Bridge at all to play from Roon; just connect your computer via USB. As far as I can tell, Roon is a non-starter for folks like me who prefer not to run a full-sized computer (as opposed to a NAS + tablet controller) to play music. But I would be happy to be proven wrong.
In case anyone has not seen it, CA has a review,
Frode said I did some more checking, and if I understand correctly you are dependent on a computer that host the Roon Server.In other words, pretty much a deal breaker to me. I imagined an embedded version…
Also, Roon may not require a constant outside connection unless you are streaming from Tidal. But I could be wrong with all this, so I will check. Good questions.
crabby saidPaul McGowan said I can tell you one thing we are committed to - and hopefully this will happen if the software gods are kind - Roon. Roon is the new Sooloos music management system and we are using it here at the Munich show and I am here to tell you it's freaking awesome!!! This is the answer boys.We’ve been waiting for the perfect interface to our music collections? Well Roon is it! Wow. More later, I am in the middle of it all but jhaving a killer time using it.
patentpending saidGreen Machine said PS - anyone got Tidal to work with Chrome + MacBook Pro or OS X Yosemite + DStream DAC ??I have a mac mini going into my DStream (USB) that i run Tidal/Chrome on using a macbook air / sharing the screen in Yosemite and works well-albeit now i’m going to look into this Roon business…
Paul McGowan saidI am running Roon on the Mac Mini at the show. Though they do not have a Mac based controlling side yet - close - and I am using an HP tablet to run the user interface. It sounds really good.
Also from what i understand there’s an iOS / Android app in the works-presumably so we can control it with tablets and phones.
I just found out that Frode is correct, you will still need a computer to run Roon. The Bridge will discover it and connect with it and you can play through the Bridge, but a computer is required. Bummer.
Paul McGowan said I just found out that Frode is correct, you will still need a computer to run Roon. The Bridge will discover it and connect with it and you can play through the Bridge, but a computer is required. Bummer.Yes, I understood this from the latest CA discussion.
If the CuBox can host the Roon Server it wouldn’t be too much of a hazzle:
Paul McGowan said I just found out that Frode is correct, you will still need a computer to run Roon. The Bridge will discover it and connect with it and you can play through the Bridge, but a computer is required. Bummer.Paul does that mean it is a given that Roon will be able to discover Bridge 2 and play files even though they do no support DLNA?
do you plan to have this before B2 ships? If so looks like us Beta testers will need to acquire Roon ( would be happy to do it if it works with Bridge 2)
this is exciting
magicknow
I just watched the Computer Audiophile video of Roon and it is indeed very impressive. It’s not cheap but you do get a lot more than with the usual music server software. I do not want to go back to a computer/USB connection to my DS, however, so I am looking forward to B2 incorporating whatever it needs to incorporate and am also willing to beta test those features. I hope PSA (I suppose that means Dennis, who already has a lot in his plate) can figure it out and it’s not too painful.
Paul McGowan said I just found out that Frode is correct, you will still need a computer to run Roon. The Bridge will discover it and connect with it and you can play through the Bridge, but a computer is required. Bummer.So the only wired connection the computer will need is the LAN ?
magicknow said
Paul does that mean it is a given that Roon will be able to discover Bridge 2 and play files even though they do no support DLNA?do you plan to have this before B2 ships? If so looks like us Beta testers will need to acquire Roon ( would be happy to do it if it works with Bridge 2)
this is exciting
magicknow
rogerdn saidPaul McGowan said I just found out that Frode is correct, you will still need a computer to run Roon. The Bridge will discover it and connect with it and you can play through the Bridge, but a computer is required. Bummer.So the only wired connection the computer will need is the LAN ?
