I’m looking to combine my 2ch and 5.1 channel system while eliminating the processor (Marantz Av8801) This scenario would make it much cheaper than upgrading the AV8801.
I have PSA 300 monoblock amps with the BHK preamp.
McIntosh MC207 7ch amp with Marantz AV8801 pre/processor
Oppo UDP-205 Blu-Ray Player
So essentially it would look like the below.
OPPO UDP-205 Front Right/Front Left XLR Output to BHK Monoblocks XLR.
OPPO UDP-205 Side Right/Side Left/Center (RCA) Output to McIntosh MC207 Right/Side Left/Center Input.
Would this work???
Looking at the Oppo owners manual I would say no. I don’t think the Oppo can be used like a Directstream Dac with internal volume control.
@audiophilehi nice avatar!
I suspect you can use the OPPO volume control and set relative volume levels of the speaker 7.1 channel audio outputs (rather than XLRs)
I don’t know what is meant by not upgrading the 8801 so maybe explain that?
You can probably feed a pair of outputs into the BHK preamp.
I’m looking to use my Oppo UDP-205 as a preamp for home theater replacing my 12 year old 8801.
I have since found this recently that explains how I can achieve this.
