OK, I did it on a Linux Mint machine. I first had to install FLAC and Opus codecs, and also Audacity. Then, I have downloaded a few 192kHz files from 2L:
http://www.2l.no/hires/
The main processing script is flac2opus.sh:
#!/bin/bash
ROOT_PATH=/localscratch/data/audio/hires
if [[ $# -ne 1 ]]; then
echo Usage: $0 file.flac
echo - Here are available flac files:
ls "$ROOT_PATH/flac"
exit 1
fi
FLAC_FILE="$ROOT_PATH/flac/$1"
if [[ ! -f "$FLAC_FILE" ]]; then
echo Error: $FLAC_FILE, this file does not exist
exit 1
fi
WAV_FILE=$(echo $FLAC_FILE | sed -e 's/flac/wav/g')
OPUS_FILE=$(echo $FLAC_FILE | sed -e 's/flac/opus/g')
LOSS_FILE=$(echo $WAV_FILE | sed -e 's/192kHz/opus/g')
flac -f -d "$FLAC_FILE" -o "$WAV_FILE"
./change_sample_rate "$WAV_FILE" 48000
opusenc --bitrate 256 "$WAV_FILE" "$OPUS_FILE"
opusdec "$OPUS_FILE" "$LOSS_FILE"
ls -l "$FLAC_FILE" "$WAV_FILE" "$OPUS_FILE" "$LOSS_FILE"
file "$FLAC_FILE" "$WAV_FILE" "$LOSS_FILE"
opusinfo "$OPUS_FILE"
OK, that change_sample_rate executable is a small C code compiled from change_sample_rate.c. Its task is to only change the sample rate and byte rate in the header of the .wav file:
#include <stdio.h>
#define SEEK_SAMPLE_RATE 24
int main(int argc, char **argv)
FILE *wav_file;
int old_smpl_rate, old_byte_rate;
int new_smpl_rate, new_byte_rate;
if (argc <= 2) {
printf("Usage: %s file.wav sample_rate\n", argv[0]);
return 1;
wav_file = fopen(argv[1], "r+b");
if (wav_file != NULL) {
fseek(wav_file, SEEK_SAMPLE_RATE, SEEK_SET);
fread(&old_smpl_rate, sizeof(old_smpl_rate), 1, wav_file);
fread(&old_byte_rate, sizeof(old_byte_rate), 1, wav_file);
printf("Old sample_rate = %d\n", old_smpl_rate);
printf("Old byte_rate = %d\n", old_byte_rate);
sscanf(argv[2], "%d", &new_smpl_rate);
new_byte_rate = new_smpl_rate * (old_byte_rate / old_smpl_rate);
printf("New sample_rate = %d\n", new_smpl_rate);
printf("New byte_rate = %d\n", new_byte_rate);
fwrite(&new_smpl_rate, sizeof(new_smpl_rate), 1, wav_file);
fwrite(&new_byte_rate, sizeof(new_byte_rate), 1, wav_file);
fclose(wav_file);
return 0;
Once the original FLAC file is uncompressed in a WAV file, the header is set to 48kHz, the WAV file is compressed and uncompressed with Opus, I was then able to compare both versions on Audacity.
Fortunately, Opus keeps the time alignment; I did not have align both WAV files. By inverting the lossy file data and by merging both files, I was able to subtract the lossy file to the 48kHz WAV file.
Unfortunately, the result shows quite a significant difference in dynamic portions of the music; in those time periods, the original file was producing sounds up to about -3dB, but the difference between WAV and Opus was still audible at about -40dB. This is a bit disappointing…
That being said, since the file was identified as 48kHz, I do not think the Opus file has lost many details. Maybe there is a way to keep both details and dynamic. Who knows…
