I have been reading a lot about how much the room shapes what we hear, sometimes more than any single component. Before spending money, I want to hear what actually worked for people here. These are the changes I keep seeing recommended:
Speaker placement first. Small moves away from the front wall and toward a proper triangle seem to cost nothing and change a lot.
First reflection points. Absorption at the side-wall reflection points is often mentioned as the biggest step for imaging.
Bass traps in corners. Corner treatment seems to tame boomy notes better than turning down the bass.
A rug between speakers and seat. It is a simple way to soften floor reflections in rooms with hard floors.
Diffusion behind the listener. Some people prefer it to more absorption to keep the room from sounding dead.
Seat position. Avoiding the exact middle of the room appears to smooth out room modes.
Measure, then treat. A basic microphone and free measuring software can show where the real problems are.
My room has hard floors and a large window on one side, so reflections are a real issue. Which single change made the biggest difference in your room, and what would you skip if you were starting again?
Seat spot goes right there with speaker placement..they work together.
I would say rug should be the easiest one do next. that really tones the room down
Slap echo - My first attempt - I did foam.com foam in the corners and along the wall meets the ceiling. That realy helped. So I would go for corners next.
First reflection next
Diffusion behind the speakers on front wall.
EDIT: forgot to mention, in the end I spent probably $3000 on Vicoustics stuff and had them create a layout for $99. WOW, it really does work. In the end compared to what we spend on crap, I mean equipment, its not really that much. But for some w/o a dedicated room that option is really not available.
Pretty much got it. I was pleasantly surprised how much a floor rug could help. As far as slap echo, a full set of Michael Green’s Corner Tunes did the trick.
Well thought out list and they all matter. Room nodes caused by excessive bass cannot always be controlled by passive means.
PSI AVAA 214 active bass traps do the most. I cannot speak for digital EQ interfaces as I have not tried them.
Like Brian, I’ve spent a lot of money on traps and panels, and the 214’s aren’t cheap, but I don’t blame the room anymore for muddiness, ringing, or an il-defined image.
This is not a selfish plug for a solution that I am a dealer for, just for a product that I can’t live without.
Nice, concise list. Have not done the corner bass traps for aesthetic reasons. Waiting till I can afford 2 PSI AVAA active traps in white color. Did two other things:
First, had a 22" wide wall built (w double sheetrock) at right front corner of the living room. My skeptical wife heard the improvement. Now both sides of living room are mirror-imaged.
Second, I carefully installed 10 basic Synergistic Research HFTs on walls and ceiling. My skeptical self heard a dramatic improvement. Cannot explain why. The whole idea seemed like hogwash till I heard it in my own listening room. Much wider and taller soundstage, somewhat greater depth, leading edge of brass instruments sound more ragged like Philadelphia Orchestra in Marion Anderson Hall (my musical absolute sound). YMMV, but for me I was stunned by these HFTs. A $500 component-level upgrade.
Your list is a good one. The ordering will depend greatly on the individual room. For my own efforts by far the biggest change was when I switched out the high back chair. Strange it took me so long to understand why the music changed for the better when I moved forward in the chair, starting to stand. Duh. Not much point on dealing with the room behind you if your ears are nestled 4 inches from the high back of the chair.
I really didn’t want to know this. I love my current chair, but have to admit that the large headrest area is for sure diminishing the SQ. It’s hard to imagine relaxing in my listening room without this:
You going to need one very high end sound processor for the speakers in that chairs “ears”
The chair I was using (dark brown) is between the FR20’s and the current light tan is in the foreground. It has a highish back as well but not as high as the zero gravity monster. I have compared sound with the tan recliner versus dining chairs (to the left of the left FR20) and found no significant difference. Got a chain saw? You could just lop the top of the back off.
Your 7 step program looks exactly right. I have large dipoles and high ceiling, so that’s not so important for me, but would make that step 8 in your list. It’s also one of the more difficult.
“Dear, I’m going to put some large panels beneath the ceiling.”
I find time and again that when my wife goes up to the cabin without me for a few days, my music room improves a great deal. Subjective perhaps, but there ya go. It just seems much more enjoyable when restraint leaves the menu.
