What would a subwoofer bring to my 2-channel stereo?
I’m very new to the concept of subwoofers.
I am curious as to what I can expect by adding a subwoofer to my B&W 802D 2-channel stereo music only system.
I’ve heard Paul mention REL subwoofers, and also noticed that Abbey Road uses REL subwoofers with their B&W speakers.
Also, I’ve been on the REL website, and wouldn’t know which subwoofer would be the best match.
Can anyone shed some light onto this topic?
thanks in advance…
Assuming that the sub is placed in the appropriate location (see “sub crawl” on youtube): you would gain some low bass extension, generally improved bass, and possibly improved clarity from your stereo speakers. Bass is not always a strtaightforward subject; you may wish to consult Paul’s excellent book The Audiophile’s Guide: The Stereo. Note that the room, room treatments, and setup are as important as any equipment we purchase. Good luck, it’s a fun process!
Heads-up as REL has a subwoofer to speaker pairing guide on line. The for the B&W 802 the S/812 is recommended for a medium sized room. The 802D is not listed in the guide, butte S/812 is a fine subwoofer.
Thanks for that info… in anyone’s experience, would I need one or two subwoofers?
Two IME.
why is that? could you elaborate
One man’s explanation:
…which is consistent with my general understanding…
FYI.
My experience with subs:
  1. DIY speakers with very good SEAS drivers. The further they are from the wall (now 3 feet to baffle) the better the sound stage but the bass really drops off due to room nodes.
  2. I had a DIY sub but could not integrate it very well so I sold it.
  3. Now using REL S/510 sub in the only available corner and it’s a keeper. Since the room is not large (14.75 by 15.5 feet) the diagonal sub alignment provides the lowest bass response in the room, but I had to build a floor to ceiling bass trap on the opposite corner. We do a lot of listening when up one floor level and that extra length of space provides very deep and clean bass upstairs. I optimized the REL sub with a very good AC cable, plugged it into my P12 regenerator and made a better high level cable. The extra bass from low 20s to mid 50s Hz improves music immensely, including better vocals and more sense of space in the sound stage. RELs claims on what their subs can do are true!
  4. Just bought a UMIK-1 microphone and now learning to use the RoomEqWizard (REW) software. It shows very well how the sub is integrating with the main speakers and room nodes.
I’m using a BHK preamp, how does the REL subwoofer hook up to the preamp?
REL recommends a high-level connection to the power amp rather than a line level connection to a preamp.
What exactly does that mean?
I’m using a pair of classe cam200 monoblocks.
Regards.
I have two T9xs. I had the 812s but that was overkill. And if you want overkill, the JL F113 is a must! I loved that thing but it was not as musical as the Rel line in imho. Subs fill out the low end in my book, not so much as “add” low end. Once everything is tuned in, listen to Thanks to You/ Boz Scaggs then turn the sub(s) off and listen again. You’ll never go back…
And then there is this (w/r/t REL subwoofers and monoblock amplifiers):
FYI and good luck with your subwoofer options exploration.
I added a Rel 212/SX to compliment my Klipsch RP-280 2 channel system in December 2022. WOW! Love the addition. I previously had an SVS PB16 in this system, but moved to the theater room in 2018 and really missed the lower range the SVS single sub provided. The Rel is much better than the SVS in a two channel stereo system while the SVS is fantastic in the theater room.
The Rel 212 SX is a two active driver system with an additional passive driver. IF your budget allows, consider the Rel subs. This made a substantial improvement to my existing set up.
I have dual subs. Love them. Go listen to some systems with subs to see if they are for you.
Now that you have had time for the BHK Pre to settle in, how do you like them with the Classe amps feeding the 802D?
Anyone have a comment, idea, insight into these products?
This is another issue I’m having with the CAM200s. Probably for another thread but I’ll describe it here as well. When I had my Bryston preamp, if you envision the volume knob from 6 clockface, full volume was between 7 and 8 clockface, very small volume range.
The BHK preamp, full volume is between 25 and 30.
I hear Paul say in a video that for maximum bass the volume should be operating around 3/4 within it’s range.
Does anyone know anything about this?
I currently have 3 subs in the room, with the subs off, a good solo piano recording sounded like a good piano recording + some. With the subs on, all the emotional content and flow, timing, and air(high registers) gets amplified and it sounded Maurizio Pollini is in my room humming alone with his master craft.
Draw back is you really need to spend time to tune the subs to match the room and speaker, when you change something major in your gear, chances are, you’ll have to retune the subs again.
