I have had for about 5 years now, a SCGD and it given wonderful service. But its time to move on up. I had been looking a Dac with analogue input(s) so I could connect my Anthem MRX 520, as I do at the moment, BUT had a small problem with the SGCD, meaning it had to go to my dealers to be fixed. Anyway he bought it back and re installed it, and I just asked him if the Anthem could connect with say an optical cable to the SGCD, he said it would, and he just happened to have a optical cable in his bag and demonstrated how to do it. Anyway the upshot of this is I have the option (which I really like) of keeping to PS Audio and going with the Stellar Gold Dac Or is the DS MK1 a better bet (although its older tech)
A DAC sounds like the filters. The PS Audio DAC’s have historically allowed the filters to be updated, and even pick the one you like over several version that have been provided. The latest isn’t always the greatest. I did not like my initial PS Audio DAC’s HURON filter as much as the last filter it used as an example. The DAC I use now has FIVE filter choices but…that’s all you get as they aren’t updated, ever.
A new DAC is just a new filter for the most part so make sure, especially if it is a fixed filter choice, that you like the SOUND. Listen, listen, listen.
Peter,
I would also consider the Steller DAC. I had the Gain Cell DAC and recently updated to the Stellar DAC and boy is it wonderful. Good Luck.
Many DACs sound so similar to each other it becomes difficult to describe any differences one might hear. Some DACs are very easy to listen to for extended periods of time. The PS Audio DACs, the MK1 DSD Sr. and Jr. are very easy to listen to. Some DACS lean towards tremendous detail, these are commonly referred to as analytical. Some DACs warm and/or enrich the sound. I prefer those myself.
I own and have tried many, many DACs. The only DAC I ever heard and owned that stood out in a way that made it totally unique is a Molo Mola Tambaqui. I owned one for four months and I was madly in love with it. But after four months I had a chance to sell it for more than I paid for it so off it went.
There are way too many DACs available for anyone to tell you anything other than they like it or they don’t. Searching for “the best” is an impossible task. Even taking price into the equation doesn’t help. There are so many under $1000 DACS, and way too many above that price.
Best of luck! I hope you enjoy the process! If you do buy a new DAC, seek a source that offers returns. I bought I highly rated DAC once that people still gush over. I personally found it unlistenable. All the heart and soul, everything I love about music was stripped out of the sound. When someone says they really love that DAC I can’t help but wonder “Who really hears what?”.
As usual Al offers experienced and valuable advice.DACs can be so different that system synergy and personal taste play a big part. Researching trusted and “understood” reviewers can help narrow the field. Earlier this century I tried PS Audio DACs and have followed them when I could afford them (not possible now with the PMG DAC but I would definitely try that if I could). Their “philosophy” and sound I have found a good foundation for my system, but I am certain there are others that would be better for another system, and likely others that I might enjoy as well or more if I could experiment.
Best of luck in your search!
If you are wanting to continue with PS Audio DACs I think used DSD Mk2 units may continue to appear and affordability may improve and are well worth seeking out–I love mine, even more than the modded Mk1 that I also have.
Excellent reaponses!
The only thing I would add is advice from, I believe, an online reviewer: If relying on opinions, it helps to know if they’re being offered by someone who shares your musical preferences. Of course you have to know your preferences and that just comes with experience.
The DS Mk1 is almost impossible to beat for the price (less than $2000) on the used market.
