It seems there is only a 2 outlets model with schuko sockets
and it has a 14AWG wire, the same og eTP609E NCF model above mentioned.
I do not find on Furutech website a thicker wired (schuko) power distributor…
Oh right, no Schuko.
Per Need extra sockets on a power plant - #9 by deafenears, Supra makes some schuko ones:
2.5mm2 internal cabling.
Thank you for suggestions.
Actually I’m giving a try to the Furutech eTP609E from the wall to feed both my 2 P12s. Ah! It doesn’t work at all! After having plugged both the P12 to the power distributor, they do not come alive. No reaction to “ON/OFF” switch on the back panel. Even if I try another outlet with a simple device (light/macmini/what else) they don’t work, it seems that no AC current is passing through the Furutech strip.
As soon as I unplug the 2 P12s from the strip, it comes back to operate as usual.
I’m afraid something doesn’t work or I’m wrong with something.
The cable from wall to Furutech distributor is a quality cord (previously I used it in my systems itself before a change for the AQ Dragons) and I tested it separately to verify that it correctly works.
Is there a limit voltage/power that avoid the Furutech to work when feeding 2 P12s?
Maybe its overloading the eTP609E. Does having one P12 plugged in work?
Near-field listening!
Enjoy.
The Furutech ETP-609NCF has no current limitations it’s just 6 receptacles in North America with a Star Quad wiring scheme. I own and use one with no issues.
Thank you but the 809 has no schuko outlets (GTX) and the 309 is filtered, not only unfiltered power distributor like others.
If I remember well you are using it not from wall to PowerPlant but from multiple sources to one PowerPlant’s outlet, is it correct? If so which sources in your experience better perform feeding together from this furutech strip (or which ones do you think have less degradation compared to be directly plugged to a PowerPlant)?
Thank you
