Any ideas why my trigger cable won't turn my amp on
Any ideas why my trigger cable won’t turn my amp on
Make sure you are using two-conductor tip-sleeve type of plug (as opposed to 3-conductor stereo tip-ring-sleeve).
it’s a mono plug, not stereo
Someone replied to your post.
| Palouse
June 29 |
If might help to list your equipment, when the trigger last worked, what changes if any were made since, and what steps you’ve taken to troubleshoot.
I’d try to see if the cable works with other units and also try a different cable with the same unit. It’s either a bad cable or a bad trigger port.
Mono plug is two conductor tip!
Did that cable ever turn your amp on?
