Trigger cable
Hi,
I want to trigger the two M700s from the AV amplifier. Does a standard stereo jack 3.5 male - male cable work, or should I get a mono one?
Thanks
R
The stereo cable should work fine.
Either will work.
Thanks, I’ll try!
I ran a longer cable to one amp from the preamp, then a shorter one from amp to amp on my BHK 300’s. Worked great and saves a couple of bucks and is less of a rats nest for wiring.
Just to confirm that I’ve used a standard stereo jack 3.5 cable and everything is working fine so far!
Thanks!
