RonP,
If you don’t design to the measured cable data, and firmly connect that to a measured problem that the device is supposed to improve what exactly should I be designing to so as to not shoot myself in the foot?
This thread is about hard data, and what it may really be doing to help. It isn’t about how we “buy” a product that can soan from your friend owns it to it has the best specs and everywhere in between.
A thread that is firmly in the discussion of the DATA, and not the variables in an emotional purchase simply means we’re in the wrong thread. If we are talking abut BBQ, talking about baking isn’t going to be appropriate. that doesn’t mean a thing good or bad about baking, it is just not the thread for that topic.
I won’t make a move on a cable that isn’t 100% firmly tested and appropriate for the application, and at the proper price point to be a good value for yes, a specific cstomer base. The entire universe of cutomers can’t be my product world view.
Someone will always be pissed off or go elsewhere to the left or the right of that reality. Every product has a world view it is intended for. We have a clash or ALL world views at the same time and certainly, some will have to feel I’m not on thier wavelength. That’s actually good!
To make nice products, you can’t build to suit too wide a customer base as it dilutes what makes the customer world views different to the point of being inappropriate. When we see divides, we can see the differenes in world views and this forces a decison be made…what view is your product being made for?
BAV and ICONOCLAST is value and data driven. If we pay attention to the data, the USEof the prodct willatch the data agnostic user (the data provides the intangible benefits) or the data driven user that also required data in order to justify a trial. The PRICE limits the amount of data that cn be supported in a specific price point.
But the 80/20 rule is still true. We can hit 80% or better the performnce for 20% of the price. That’s the products world view. We can’t afford to build theory today for proof it may work tomorrow designs as this level of tech can be fun, but many can’t afford the tech experiment.
Let’s look at shielding. OK, a proper shield can knock EMI/RFI down 80-90 dB. EMI/RFI coming into, ingress, or out, egress, of the cable. That’s a lot of attenuation. But it is a RATIO so we need to know more. 80-90 dB of a micro-volt or a million volts? If we have a million volts and 1 volt signal, 80-90 dB may not be enough! If we have 120 volts signal and micro volts EMI/RFI it can be meaningless.
Data is also misleading when we realize it is a lot of reduction of terribly small incident ingress signal. FCC limits control what can go OUT of our stuff, so we may have to use a shield for EGRESS if we have a noisy device. Seldom is a power cord shield for ingress.
EMI/RFI can’t go very far at the frequencies it resides with much power. “Strong” is relative to the signal we are moving. The power level in a power cable is tens of orders of magnitude over a speaker cable (not shielded). We can have 120V at 15A in a power cable. a speaker cable is MAYBE 50 volts and MAYBE 20 amps or so. And either is thousands of multipliers larger than the ingress EMI/RFI “noise” on the cable.
The signal is simply HUGE over the noise. The DATA on how the shield works (80-90dB isolation) is one part of the answer. Understanding HOW an attribute may be a benefit, or to what extent, is the other. As long as people know BOTH sides of an issue they can decide if the attribute is worth the cost.
Will we have shields? Maybe, but one thing you will be told is how much it may be a benefit. Those that understand the data can affirm to those that don’t a product is worth an emotional evaluation…like driving a car. At that point you can ignore the data but…knowing that those that DO understand the data support the product in the technical regards. We can’t absorb every product at the data level…we need assistance most of the time. The data will be there for those that understand it, even if they are the few, the necessary few, for the rest of us.
I started on this foot decades ago, and I will remain on this foot.
Best,
Galen Gareis
