Most say that the UP OCC is the most neutral. But, with the series II the differences are mitigated by the improved design changes in the cable over the series I. That’s exactly what we want, to get the TPC to be better than the UP OCC in the series I IC cables. And, the series II TPC is cheaper than the UP OCC series I. Design is most important BEFORE the copper.
I can’t get my GTI to go faster just by changing the tires, the fundamental car is more important, and if the car is greatly improved the tires won’t hold it back but sure, a better tire can now be leveraged even farther.
That’s the general concept of ICONOCLAST. Mess with the DESIGN before you apply materials. Get the best design so any materials you use are pushed as far as you can go, and that improves the VALUE since less material performance is left on the table using an inferior design. Materials can’t improve a design’s R, L, C and Vp. They are unchanged by copper materials tertiary minor draw science properties. The best design is ALWAYS going to be better than the lesser design no matter the copper used. THAT I know from the measurements.
Of course, the copper changes in series II will offer differing flavors of sound, too, just not as course in timberal balance. Some of the analog non linearity is designed out in the series II in the analog frequencies.There is now less to “hear” since the improvements and changes are across all the cables. We only change the copper in ICONOCLAST, not the design, in a construction.
OK true, the BAV XLR is the exception. Here I had to change the dielectric to meet an over reaching requirement, flexibility, and keep 95% or more of the electrical measurements. The BAV XLR also had to be AES/EBU digital and analog, both. This restricts the conductor design (no quad conductor stranding) so we maintain durability an a 100 ohm impedance for digital. This is the “optimization” for studio use.
Also true, do NOT use the speaker cable auditions to pigeon hole the IC cables copper choices, it won’t work. You need to start over for each. Even if he copper is the same type, the LOADING on the driver circuits respond differently to the cable properties.
ICONOCLAST was intended to bring superior electrical at as affordable prices as possible with the TPC copper. The better copper is always going to be a jump in price and sound different and not always the same for everyone. Since we COMPRESSED the prices as best we could for the IC and speaker cable, we don’t go from 1K to 35K cables, it will allow more people to realistically save for what they really want. No, still not everyone as this hobby adds up fast but we honestly try to get you farther for less.
The system components you can get starting out eclipses what I had available to me in the 1970’s by many orders of magnitude. Don’t for a minute think you can’t get high-end today at a far, far better entry point price. And yes, that includes cable.
Best,
Galen
